waggy 44 install Q
jallen
dallas
so i go to the local pick-and-pull and get a waggy front 44 to put in my '01. can somebody reply with a parts list (including #'s if available) of the HAVE TO parts necessary for the install as well as the WOULD WANT TO parts mecessary for the install.
i just want to make sure i'm not overlooking anything in my pricing.
thanks.
To start off, you'll want to regear.
Then you'll need to Fabricate new coils mounts, shock mounts, trackbar mount, LCA & UCA mounts. This will take the major time when doing this swap.
does anyone make a kit for this, or does it all have to be fabricated by hand?
also, what would the waggy axle be geared at (most likely)?
These are made for the TJ, but you can get around that.
For the price they're asking, I would fabricate my own. :sure:
2.72,3.08,3.54 are the most common gear ratios.
MOre usefull Waggy info here...
http://www.rps4wd.com/tech/dana44.htm
