visual differences between ford 9's
bluejeepkid
Bullhead City
Are there any visual differences between the small and big bearing ford 9's?
Tia
A small bearing housing can be differentiated from a large bearing housing by the size of the nuts and thread used to retain the brake backing plates to the housing, the small bearing housings use 9/16 socket size nuts with 3/8” fine thread, while the larger bearing use 3/4” socket size and 1/2” fine thread. Gross Vehicle Weight ( GVW ) would determine which axle housing many cars and trucks received
hope that helps
