- Austin, Texas
Just got the Jeep back after a full AX-15 rebuild and a rear axle replacement (rebuilt 8.25 chrysler 3.07). So all of that stuff is "new". That said I'm having two problems, which probably aren't related. Mostly I'm asking about what might be causing a slight but noticeable vibration above 35mph most noticeable in 3rd gear when accelerating gently. Goes away if I shift into neutral and is better if I let off the gas.
Second problem is 4WD won't engage at all. Feels like maybe just mis-adjusted shifter. I may try the trunion adjustment myself but may just make the shop check it. The vibration worries me more with a big road trip coming up.
