I need to pull my valve cover on my 94 4.0 and replace the pcv valve
she has about 186k on her. Is there anything else I should do while I have the valve cover off?
What is the torque for the valve cover bolts?
Replace the valve cover gasket if its old or torn-up looking or crushed down a lot. Torque is light hand pressure with your hand choked up all the way against the head of the ratchet. Move your way from the middle bolts outward toward the ends simulataneously and your gasket will seal well (given that you properly cleaned your mating surfaces as you should). Most valve cover gaskets are cork and need no more than 10ft-lbs of torque. The idea is not to crush the cork but to simply provide some seating pressure.
Just happened to see something I knew the answer to when I was looking for some more threads on Heater box removal .
Not sure what you are replacing, but there is no pcv valve on the '94. If you are dealing with oil in your air cleaner, this can usually be corrected without removing the valve cover.
auto trans? make sure to re-adjust the line pressure/ throttle valve cable after you finish. Assuming it runs over the valve cover on a '94, it tends to get boogered up when it's moved to make room for the cover to come off.
