thebluebuffalo
- Kentucky
what is the small black container in the front bumper on the passengers side? i'm removing the front bumper and found it. is it important? where can i move it so i can have a custom bumper?
JoeOffRoad said:It is your vacume that helps control different things... heater, cruise, etc... you can relocate it near the firewall on the pass side... you just have to move the vacume lines.
Funky Fresh said:sounds interesting......
.....i hit sumthin a while back and bend the shit outta my front bumper right where the vaccum bottle is.....now im having these problems...http://www.naxja.org/forum/showthread.php?p=243765248#post243765248
could those problems come from the vaccum bottle being messed up?
thebluebuffalo said:sounds possible
jeeptx23 said:When you have your Jeep running and the hood up, do you hear any kind of noise that sounds like a sucking sound or an air leak? You can use some brake clean and spray around the noise with your engine running and when you spray over a spot and your engine stumbles you have found your leak. If you infact have a vacuum leak it could cause a lot of the problems you have described and more.
