The weld on the passenger side Upper control arm mount has cracked. it id the portion of the weld on the mount not on the axle tube.
What is the best way to repair it? Grind out the entire weld or just run a new bead over the area tha has failed?
I'll be using a wire feed welder with flux-core wire.
I plan on adding a gusset to the open area of the mount also.
