bdiamond
- Wichita Falls, TX
I have searched already, I think I know the answer but I still just want to confirm. I have found a non-disconnect front axle. It is in a 90 cherokee with ABS. I'm not sure what transfer case it has in it.There are tone rings on the axle shafts. Will this axle have the big u-joint shafts? Or did they start that later? Are they any better or worse than the later axles? Thanks...
