the axle side jounce plate (in the cent of the coil spring kinda looks like the top of a mushroom) there is an indent in the center of that. You drill it then tap it...get the hockey puck drill through the center of that. feed a bolt threw it and tighten it down....simple and an easy way to bumpstop....
not just one hockey puck will be used you have to measure it accordingly, if you have a lathe or know of someone you can have bump stops custom made (using a different material) to length for precise bump stoppage
