emr1101
- Raleigh, NC
Hey does any one know the actual heights of these tires? I know the TRXUS MTs are hard to balance, but what about the maxxis?
aka, go with the Trxus.. Great tire for the priceeace:all tires are different, the same tire will not even last the same amount of time, it all depends on weather conditions, where you travel and a couple other. And for the balancing, ive balanced the cheapest tires and i have seem them 10x better than any expensive tire out there, visa versa. this goes both ways. it depends on the plant that makes the tire. not every time the machine will line up the inner liners which support the tread, sometimes they will be off a fraction and mess up the complete roundness of the tire. ive seen bias tires rounder and balance better than some radials out there. it all depends my friend
:huh:aka, go with the Trxus.. Great tire for the priceeace:
:huh:
:bs: Anything Interco sucks!! If you do not mind adding several pounds of weights and replacing them every 10K..................I would rather run wagon wheels!!
x2~! they only suck on road. swampers go everywhere!Sucks? I guess you have never wheeled on a set of swampers!
