xjh3
- Moodus, CT
D30 setup for 3 link
3.55s
Aussie
Ballistic truss
Lower mounts flush with bottom of tubes, 5/8" bolt hole
Upper mount, driver's side (bracket, not bushing) 2" ID width, 5/8" bolt hole
Gusseted inner-Cs
OTA trackbar mount
Shortened Teraflex trackbar, poly bushing/2" flex joint. Joints BEAT. Poly bushings readily available, I have a rebuild parts for the Ballistic joint.
OTK steering using RHD drag link and ZJ tie rod, BEAT.
Rock guard (a little bent)
Ball joints and unit bearings one year old
$300
8.8
Setup for XJ leafs
3.55s
Welded
Discs
Ruff Stuff cover
Lube locker gasket
Conversion u-joint on flange adapter thingy
$200
33x12.50r15 grooved TSLs on 15x8 American Racing Outlaw IIs
All hold air. Wheels have lots of rash. Balanced with BBs.
Don't hate, they follow their 35" BFG/MTR bretheren around without issue.
$200
Firm on prices. Located in Moodus, CT.
3.55s
Aussie
Ballistic truss
Gusseted inner-Cs
OTA trackbar mount
$300
8.8
Setup for XJ leafs
3.55s
Welded
Discs
Ruff Stuff cover
Lube locker gasket
$200
$200
