ubercurtisb
- Chandler, AZ
On Sunday while driving home, my Jeep just stalled on the road, while I was cruising at about 40mph. I coasted to the center lane, put it in Park, pulled the key out, and then put it back in and it started right up again. "Whoa, WTF? That was weird..." And then it happened 5 more times on the way home. The CEL came on after the third or fourth time, so I pulled into O'Reilly's and had the code read. It showed up as P0320 and P1391. So all fingers are pointing toward the Crankshaft Positioning Sensor. I only use OEM Mopar parts for my Jeep, so this morning I took it in to Tempe Autoplex's Jeep dealership (Stalled about 20 times getting there, but never had trouble starting it right back up) where they pulled the same codes and told me it was the CPS and the Camshaft Positioning Sensor. I don't like to screw around, and I want it done right, so I said "Alright, do it to it."
After waiting 3 hours and paying $360, I got my Jeep back. Drove home with little to no issue, except maybe a minor hiccup, which I assumed was all in my paranoid head. After a few hours of studying for a test, I get back in the Jeep and go to school, and it just didn't feel right. s I got off the freeway, my speedometer went loopy, and went far past the 100mph and then back again, and the oil pressure gauge dropped for a split second, and my "Check Gauges" light came on, and then everything went back to normal. On my way home from school, this happened about 5 more times. All of this was happening as the engine seemed to want to stall, but it didn't. The RPMs, Speedo, and Oil Pressure gauges all went loopy several times. Maybe a misfire or something, I don't know.
I"m worried because all of these symptoms are showing up after replacing these parts that I had the dealer put in. What else could be going on? Could the dealership have missed a step or two? It wasn't doing any of this on Saturday.
Specs: 2001 XJ, 4.0, auto, NP242, 143,xxx miles.
