98XJSport
Destiny is the rising sun
- Western Maine
I have a 2000 toyota celica as a DD. It's a 6 speed manual. Over the past 2 days Ive noticed that when I downshift from 5th to 4th it grinds. If I go fast, its barely noticable. If I try it slow its quite obvious. From looking around Im thinking syncro gears. Im assuming all trannys have something along those lines, does this make sense?
Second part of the question would be what are the syncros considered? I ask because I have a warranty on the vehicle. Transmission parts that are covered are gears, input and output shafts, bearings, overdrive housing, and transmission case, or damages caused by the failure of covered parts. Looking at over $1000 parts and labor if through a dealership, so I really want the otherwise useless warranty to pick this one up...
Thanks for any and all help, I trust the mechanical knowledge here on
than the celica site I lurk on, although I will probably have to ask there as well.
