yes, again the drop kit does not effect the relationship between the trans/mount/crossmember.
Be advised, there are two different trans mounts, one is 3" tall, the other is 1 1/2" tall--make sure you get the correct mount. The defining issue is if the exhaust hangar comes off the steel plate that is bolted to the transmission you need the 3" mount.
