Transmission lines - which is which?
jbeintherockies
Aurora, Colorado
Hello,
I tried the advance search using "trans cooler" and "trans lines" and it didn't turn up anything. I have also googled for the answer, but found conflicting answers.
So, I will ask:
Which trans line going into the factory radiator is the feed line (hot line) and which line is the return line (cold line)? I tried touching them both, but they felt about the same to me.
My XJ is a 2000 Limited and it is completely stock (at least the cooling system is) except for bigger tires and a Rusty's K&N conical filter setup. The radiator is the original (155k miles).
See if this helps.
