jeepman121
- Ohio
I just bought a 95 XJ country. It will go into 4H not 4low. you really have to slam it back to get to 4 low and when i go from neutral to drive it just grinds. the previous owner said it's done it before and that the shifter isn't able to go far enough back. a mechanic said that the low was out and the high was next to go. Now, I also own a 92 XJ 5-speed AX-15 with the 231 alsoin it will they swap directly, or will the outputs be too short or long?? Thank you fellow Jeepers -----Josh
