Transfer case leak
rehberg79
Byron, Il
My transfer case (231) has developed a leak. The fluid is running down the shift linkage on the driver side. Is there a seal around the bolt or shift rod (whatever it's called) comming out of the tc? I'm also thinking it could be the front output seal, but it's not dripping anywhere else. If it's the front seal does the tc have to be pulled to replace?
Also if you have seal #'s that would be great.
TIA, Mat
Found It! :eyes:
By the way, your first link was very helpful also. Theres alot of good info there.
Thanks alot, Mat
