- Waukegan, IL
Does anyone know if the trans from an 84 xj swap into a 91 yj (tj?). I know that the bell housings will have to be swapped....the wrangler has an internal slave. But will there be other issues? they are/were both 4 cyls. the wrangler come into the shop with 3rd gear half stripped off the cluster shaft ! is an ax5 an ax5 or did they change more than the bellhousing throughout the jeep models/production runs
