Trackbar Length
All, I have a 2000 Cherokee that I just swapped the front end on (installed a new Dand 30 that was NOT bent). Axle sits 1/2" toward the drivers side & I suspect the trackbar.
Anyone have what the length of the trackbar should be? There was a previous post with the same request, but the requestee got no responses. I think the trackbar mount might also be a little tweaked as well. Might try slipping it under my press to try and make it 90 degrees again. I'll post the results here.
Thanks for any responses!
M Randolph
