Spearfisher XJ
- SoCal/Maritime Academy
Recently went from a 4.5 lift to a 5" lift (Just Replaced the springs basically), and plated the frame as well. I've always had a bit of a shimmy from the front end for the past 2 years, but now I've contracted Death Wobble. I'll rotate the tires, get them balanced, and get it aligned in the next couple days. But, I had my buddy steer the XJ while I looked at the front end, and noticed the Track bar had some play in it. The play was from where the Track Bar mounted to the frame. I was wondering if it is normal to have play in it? It is a bushing, no? It is fairly noticeable, probably around 1/6 of an inch of play. I already torqued everything to spec. I know the steering box has some slop in it, but I'm not in the mood to drop that much cash on a new box if it is something else.
1988 XJ, Currie HP 9" F/R, Custom Lift, 33 BFG's, 4.0
