goosecockxj
- parker CO
Heres the problem, my 94 auto wont shift till what seems like redline. It did this once before but only for a day or two then went back to normal. we had the huge storm here in co and ever since it has started doing this again, i can get first through third but it wont shift till redline. The idle is also low at stoplights and sometimes will die. i have adjusted the TV cable and cleaned all the connectors. i did the "key trick" and the only code i got was battery was recently disconnceted which it was. I tried testing the TPS but only the connector with 4 wires going into it. That seems to be the one that would cause the tranny problems from what i understand. plugged or unplugged idle or WOT i get .8 volts from 2 of the wires and roughly 12 volts form the other two wires. i think i should be getting .5 from one of them at wot from what i understand. i have also checked the tranny fuse from the fusebox and thats fine. when i looked at buying a tps the pics are all of the connector with 3 wires not 4, does the 4 wire go by a different name? am i testing the right part? i printed out a sheet on testing tps's so im gonna try to test the 3 and 4 prong tonight but to be quite honest im not sure i would recognize a bad tps or know if i was ordering the right part to replace it (the 3 prong, when i think i need the 4) please help if you can cause if i dont fix it by the weekend its going to a mechanic and i hate doing that if its an easy fix
