if you're towing at highway speeds, pull the DS and put a couple bags over the tail shaft housing with rubber bands. The peace of mind is worth the effort-- unless you really might want a new transfer case when you get where you're going. It would only take someone accidentally knocking it into gear or a big bump jarring the linkage to poop in your Post Toasties!:wave:
