mrtosh
- Woodbury, MN
Well I may be joining the 0331 head club here sooner than expected. Gonna pic up an Alabama cylinder head. I've changed quite a few heads but on the LS series GM rockers all you did was torque them down to 26 lbs ft. And go(self adjusting). My understanding from the Haynes manual you bring each cylinder to TDC to both remove and install the rockers to 19 lbs ft. ? Without a distributor though am I limited to the blow the finger out the hole truck or screwdriver trick? Or is there a better way? Then would you do cylinder 1, then 5, 3,6,2,4? In the normal during order?Thanks in advance guys,Sean
