torque values, lower arms & u-bolts,tcase
00xj
West Michigan
Hi,
Got my lift on just need to double check some torque values. I'm also splitting my 242 for a sye,
Lower arms,
Rear Spring U-bolts,
Track Bar,
Tcase,
Ubolt straps on rear pinion,
(anything else?)
Thanks
lower arms- both ends--133 ft lbs
u bolts------52 ft lbs
track bar axle bracket nut--74
track bar ball stud nut------62
u bolt straps---14
Wayne
Re: torque values, lower arms & u-bolts,tcase *track bar*
I wanted to correct one bit of information here. The torque value listed for the axle end of the track bar probably came from the same Haynes manual that I used and it is not correct! That bolt is M10 coarse thread 10.9 hardness.
I believe Haynes did not do their conversion from NM to Ft. Lbs. The 2000 XJ FSM says 40 Ft. Lbs. for this bolt.
Don't ask why I know that 74 Ft. Lb. is too much torque for this bolt.
