blistovmhz
- Vancouver, BC
98 XJ, 6.5" LA lift, 63" chev leafs, 35x12.5r15 KM2, bilstein 51xx, OTA/OTK 1tonne steering, frame stiffened and braced, lunchboxed d44 and d30, RC long arms.
I've brought this up before but never found an answer.
I've got torque steer on acceleration and deceleration. 95% of the time it pulls left on accel and right on decel, but only with engine torque. Brakes keep me dead straight every time. The harder I torque, the more it steers. That last 5% of the time it'll steer the opposite. Right on accel and left on decel. I've never been able to determine what's changed just prior.
The brakes stopping straight rules out trackbar/draglink angle, which are dead parallel anyway and nearly the same length (same length ratio as stock at any rate).
Jeep almost always pulls slightly left on a cruise with very light positive torque. If I chuck it in neutral and coast, it's dead straight all day. Engine torque is the only thing that causes the steer.
Leafs are brand new and dead level. Problem was the same before swapping leafs. I originally thought the problem was caused by my old XJ leafs being raked back a few degrees, but the new leafs and mounting locations didn't change anything at all.
I've checked every joint a hundred times and measure my wheelbase for square. Steering self centres perfectly every time and front end is perfectly aligned (I'm positive on this). I've rotated the tires several times with no change. I've put a brand new tire on each side (one at a time to make sure my tires were NOT the same size) which changed nothing. I've tried airing up and down (I normally run at 30psi as I'm a 5000lbs rig). Control arm bushings and JJ's are all solid. I've disassembled them all for inspection and made sure they're tight. I've got only a very mild wrap considering the v8 power, and either way, adding in antiwrap didn't help. I even stuck on some 250lbs/in overloads and rode on them to make sure wrap wasn't the problem. No change.
As far as I can tell, the problem started when I threw in the rear d44 (with a lunchbox). This was before I did the 1 tonne steering.
There are a hundred threads on this, but the ones where the owner had ruled out all the obvious stuff, no solution was ever found (except in a few cases the guy would replace the locker and problem goes away). I understand suspension dynamics pretty well and I can think of a hundred possible suspension related causes of torque steer, but I've ruled them all out in my case. I'm pretty confident the issue originates at the locker but I can't figure out why and it seems like a lot of threads draw the same conclusion. I want to know why. SOMEONE must know right?
I'm wide open to suggestions. I ignore anyone who replies with "it's a Jeep, don't expect it to handle like a Lambo", but at the same time, I don't expect it to ride like a race car. When I say there's a suspension problem, I do mean it's a real problem. I daily drive it but I'd never let anyone else take it on the highway (other than my roomie, cause he's competent). Even being very familiar with the torque steer, I'm not entirely comfortable driving it at speed. If/when I need to speed up or slow down in a hurry, it'll torque enough to throw me right upside down if I'm not VERY ready for it. Constantly have to pull left during a cruise, and if I let off the gas, I have to compensate with the wheel every time. Really sucks when someone tries to rear end me or slams on the brakes in front of me.
So, who's ever found an answer? I feel like it's gotta be funkiness in the locker but I just can't imaginate the dynamics of what'd be going on.
P.S. The one thing I haven't tried is running smaller shoes. I'm guessing, if it's the locker, that bigger shoes will amplify the problem so smaller should make it less noticeable. May try that today, it's just a bit of a heat score running stock tires on my rig which is a heat score regardless
