Oatmeal
- Cedar City, UT
I have a '96 with an AW4 and it seems (not sure) that my torque convertor isn't locking up like it should.
I'm on 33s with 4.88 gears and the correct (41 tooth) speedo gear but, when at a steady highway cruise, give it a little gas and the tach needle will show in increase in rpms with no increase in speed (like it's coming up to stall speed).
I'm very anal about maintenance....fluid and filter changed regularly and have a pretty good trans cooler.
How do you check to see if it is in fact, locking up and is there a sensor or solenoid that controls this (might need replacing?)
Thanks
Hans
Thanks
Hans
