Super mud
- Bel Air Maryland
87 with supposedly a 88 4.0 and aw4. np231 and 4.10s to match the 31's. Unknown mileage on the motor and trans. Fluid changed to atf+4, with cooler and remote filter.
TPS is adjusted correctly. I'm going to double check the TV cable cause it didn't seem to set right the second time. Also Power and Comfort mode doesn't change it but does change shift points.
The jeep has been doing it since I got it (2 years) but under normal throttle it locks up in 2nd at an appropriate time and stays locked through 3rd and 4th. WOT it locks up right away in 3rd gear and also down shiffting into 3rd locks up exactly like at WOT. Never unlocks in 4th. Any ideas? I only found stuff about it not locking up. Thanks
