This is kinda related to XJ and since I still own an XJ I hope you'll find it in your hearts to help. I've swapped a '95 XJ 4.0 and AW4 into my '82 CJ7. The torque converter wont lock up. I've gone through many tests (TPS, brake circuit, speed sense etc.) and changed the TCU. I've looked at the TCU on a DRBII and it had no trouble codes but it said that the brake pedal was pressed. Since the brake pedal was not pressed at the time, I cut the wire to the brake pedal leaving the circuit open, and it still thought the pedal was pressed. That's is when I changed out the TCU. I wired the lock up manually and it now works (but only when I throw the switch) So I figure that I can rule out a bad solenoid.. Has anyone else had this issue what was the fix? Is there a difference between PCMs that could cause this problem like as if the previous owner unknowingly replaced the PCM with a manual trans PCM?
Thanks
-Dave
Thanks
-Dave
