bimmerjeeper
- USA
This top shock bolt is actually getting HARDER to turn as I slowly get it off. It is now fully stuck again. The channel locks are starting to slip off the shock sleeve, and I am starting to mangle the sleeve itself, since I need to regrip the locks after every 1/8 turn I can manage.
It literally took all my strength just to make it rotate each 1/8 of a turn. It's like when you finally break free a lug nut. Except it's for EVERY single 1/8 turn! I am actually screaming out loud like I am doing squats at the gym or something. I'm going to be sore from this, that's how hard I am turning just to get it to budge. Should a bolt be THIS hard to turn? I just can't spin the bolt any further, and the shock sleeve is starting to disintegrate. This is brutal.
I didn't wire brush the threads before trying to remove the bolt off the rusted stud. I only PB Blasted it. Do you think rusted metal shavings got caught inside the nut? Is the bolt basically stuck for good now?
Any last advice before I pay a local mechanic $100 to dremel off the bolts for me?
Thanks to the posters in other thread who offered help to get me this far.
