MaxxXJ
- Bakersfield CA
All started with a few templates
I cut them ground them and drilled them from 1/4" plate
Had some 3/4"x 2 5/8 flat strap and cut and drilled them to fit a 3/4" d ring
Brace installed
Started with just 2x6" .120 wall square tube
I didnt want it to warp when I welded It up
Cut the holes for the d ring mounts
Welded them to the front back and bumper mounting bracket
Cut and bend the corners for clearance
Cut and folded it to the contour of the front end
Before paint
Brace installed
Before paint
