So I've noticed now that after installing HID's, that when I listen to the radio there is a ton of background noise when my headlights are on. As soon as I turn them off, its clear as day
The noise doesnt go up with RPM or anything. Even does it when the truck isn't running.
Do I just have a bad ground somewhere or something? Should I isolate the radio from the trucks electrical? Or just not use the ground wire thats part of the factory wiring harness?
Thanks!
Thanks!
