dieselenthusiast
- Zuni Mountains, New Mexico
How do you know that the mopar stroker is actually quality? Do you know anyone that owns one? Do you even know what is inside it? Any one can put a warranty on an engine, it does not make it good quality.
The engine was heavily field tested in Moab, out on the highway, and in other areas of testing. The engine passed the same powertrain testing as all other Mopar remanufactured engines. They used the ATK remanufactured long block. Mopar used, “roller rockers to actuate upsized valves housed in new heads. Hypereutectic pistons, which contain a percentage of silicon to harden the aluminum and prevent scuffing, are supplied by Sealed Power. The new cylinder dimensions are 3.875 by 3.906 inches, because "4.7 is about the limit," Muldoon told us. "Beyond that, you're pushing it." The engine also contains a heavy-duty timing chain and a high-volume oil pump.”
I was giving the OP an alternative option that had not been mentioned yet. This is not a debate over which engine is better built. This is simply an option for those who may prefer to pay a little more for a factory like warranty.
