I have a few questions about the TNT unibody stiffeners. I currently run the Y-Link, but want to add their frame stiffeners to strengthen the unibody as much as I can. I have a 6 point cage, which I intend to tie into these stiffeners. Would adding these stiffeners really improve my ride quality and stiffen the truck up some? Are they fairly easy to install (prep-wise, as I can weld very well).
What is required in terms of preparation to the existing frame rails and do you have to weld up the entire stiffener or is it a segmented weld? Will I need longer bolts for the Y-Link or will the existing bolts work? . Any instructions or tips are appreciated.
