- Up s*&^ creek with a paddle!
I know its kinda tech but not totally xj related so here's my question. Will a 97+ xj tranfer case bolt into a 05 tj without much trouble? My friends 05 tj (auto, think its still I6 but not sure) was in 4 hi travelling on the road when he slide off into a snow bank. Since then his tcase is stuck in 4hi. It seams as though its in 2 hi based on lever inside the cab and outside (saw it shift underneath) but if u try to put it into N it fights and doesn't go. I was going to remove the front driveshaft until I had time to really look into fixing/swapping tcases but it didn't seam at a quick glance that the driveshaft comes off at the tcase front. This is causing me to second guess if an xj one works. Talking to xjbump he said it should minus the fact I'll need to take the front seal off the old tcase and put it on the replacement. Anyone actually done this before?
