OverlandZJ
NAXJA Member # 101
- Bristol,PA
Seems i'm replacing the rad in my XJ's every 3 years or so. They all keep splitting at the plastic tank.
Where can i get a metal tanked rad?
Blaine B. said:Yea, or from radiatorbarn.com. I love my 3 core CSF from radiatorbarn
Blaine B. said:Yea, or from radiatorbarn.com. I love my 3 core CSF from radiatorbarn, and their warranties are extraordinary. They are an honest and good company. I've heard good things about Dirk too but never bought from him.
Spanaway Mudder said:hmmm..this is kinda funny...I guess all the metal ones are here in the pacificNW!!!!
get a 91 or newer 4.0 model radiator ...that way you dont have to deal with the closed loop junk...just a thought
Slonopotam said:When you order from radiatorbarn online, do you select "radiators" or do you select "CSF racing radiators" ?
When I go to "CSF racing radiators", there is no option for a jeep.
When you select "radiators", it does not say anywhere it is a CSF. How do you know then ?
One more question, what do the following lines in the radiator description mean ?
Transmission Oil Cooler: YES
Engine Oil Cooler: NONE
Thank you,
Andrey
Blaine B. said:The transmission oil cooler is a cooler in the radiator for the transmission.
Nope. Mine does not have it - I am sure, parts list shows transmission oil cooler as a separate part.Blaine B. said:All of the Jeep radiators came with it I believe, even if you didn't have an AW4 auto.
Slonopotam said:Nope. Mine does not have it - I am sure, parts list shows transmission oil cooler as a separate part.
I do not remember anything dedicated to oil cooling in the manual transmission. It is suggested that CSF and all other aftermarket radiators have a transmission oil cooler attached or built into it.Blaine B. said:Are you talking about the aux (external) cooler or the cooler built into the trans?
Slonopotam said:I do not remember anything dedicated to oil cooling in the manual transmission. It is suggested that CSF and all other aftermarket radiators have a transmission oil cooler attached or built into it.
OEM radiators are different for manual and auto transmissions.
