Tire Tread
XJCasper
NAXJA Member #1042
Yelm, Washington
Noticed I am starting wearing down my tire tread.
For Naches? Should I run the tires with better tread in front or back?
Thanks
Jason
I would think since there will probably be no mud, you should be ok unless you have very little tread left. How much tread do you have Jason? 1/2", 1/4"?
Hans
about 1/4" in front
about 1/2" in front.
My spare is new. I did not want to have to spend more money, but I could get one more new tires and throw one of my 1/4" treaded tires on top.
Should the lessor treaded tires run on the front or rear?
1/4" is getting pretty slim. There won't be much mud but there is dirt(kinda like driving on FINE flour) What kinda tires do you have? I would say get one more tire and you should be good. Stop at some tire stores and ask if they have a good used tire of your brand. Usually you can pick them up for $25-$40.
Hans
BFG Mud Terrains.
Guess I will utilize my low tread as a spare until after Naches.
I know shops put the new pair in the rear. Is there any reason I should be the better tread in front?
Wouldn't you want the good tires in the rear so the weight transfer on acceleration will be to the good tread?
Good thread--- I see the points on both sides... but I still put the best tires up front for braking and steering. Had several blowouts/flats in the back and it was no big deal at all. OF COURSE none of this was over 55 MPH.
