themangeraaad
- Halifax, MA
So I was driving down the highway and something tore a nice hole in my tire, luckily I was able to keep it on the road so my only problem is that I need a new tire. I have 33x12.50 Mickey Thompson baja radial MTX's. My question is: Is there a problem that the tread depth on a new tire is 18/32" and I measured my tires to be approx 14/32"? Would that cause problems or is the difference small enough that I would be fine? I am on a relatively tight budget so if I can get away with it I will just get one tire and put it up front, so it wont be on drive wheels, unless it may cause serious problems, then I will pick up 2 and have a full size spare, but that would more than double my cost, so if I can avoid it at all I will for the time being. Just with winter coming up I need the four wheel drive and everything in good shape, so I need to be sure I wouldnt be causing more problems with something like this
