Archdukeferdinand
- Boone, NC
I'm looking for any tips when it comes to modifying axle housings.
My biggest concerns are heat/warpage and machine selection. I've got a 175 amp lincoln mig that I use mostly and I'm most comfortable with it. I've also got an old gas powered miller stick that gets better penetration than my mig will ever hope to but might be overkill for a d30 and 8.25 housing?
Next would be any timeframes or good patterns for weld/wait. Can I just alternate where I lay beads down and do it at once or do I need to have a long cool down after each little bead is laid?? I know that's stretching it but a ballpark would put my mind at ease. I know I'd figure it out but I like to ask questions.
Thanks for tolerating newb questions. I also wonder a bit about cutting things like shock mounts or spring perches. The torch or grinder cause any heat warpage concerns?
Edit: In addition to little stuff like shock mounts I'm looking at doing some trussing. I presume the truss puts heat on one side the whole length so warpage would be a real risk there?
