rookcherokee
- Murrieta, California
Tie rod end on rustys track bar broke. Well actually just the bolt. What can I use to replace it?
A trackbar that doesn't have the name "Rusty's" on it.
It did break. the top nut snapped off. I was wondering if I can just go into a auto parts store and pick up a replacement? Also, I'm on a 4.5" lift so that's not an issue. I just need to get it replaced asap. Thanks guys
yes you can go into any parts store and get the replacement, but you need the part number which should be on rustys site or on the tre itself. i highly recommend getting a name brand like moog or other quality brand. dont get the cheapest tre they offer. if the trackbar tre breaks while driving and you could have serious problem, especially going around a turn.
my next upgrade for my 89 with 4.5" lift is a hd trackbar with flex joint and bracket for a double shear mount. im most likely going with RE or similar design.
Alright thanks, this should be it correct? http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Product_Code=52000599&Category_Code=ste
I'm also going to upgrade, just don't have the money at the moment.
Cut your losses and buy from another company. I just put on the RE 1660 trackbar and it is solid as a rock.
