- Gassaway TN
The bottom bolt of the thermostat housing is stripped in the head. CRAP!!!
It's an '87 with 255000 on the odometer.
What is the best way to fix the problem?:helpme:
Drill the hole and tap new threads?
Drill the hole and use a helicoil insert?
JBWeld a stud in it?
Another solution that I haven't a clue about?
I ask because from looking in through the thermostat hole there doesn't appear to be alot of metal to drill into. I don't want to drill into the water jacket...that would be bad.:scared:
