hot_rod_hooligans
- Indianapolis
Not sure how it happened, but somehow I ended up with my buddies Craigslist find. 89 Sport Truck, 2.5L, AX4 4 speed, 2wd, power steering, no AC, 348k, Jasper engine somewhere around 300k. It needs some TLC, the back of the drivers side of the bed has been hit, not bad enough to damage the frame or inside the bed, so it's repairable, but I'd be better off trying to find another bed, or a new bed side from a donor. The steering is BAD. Not death wobble bad, but my Dads 61 Impala is more responsive. Not sure if it needs tires balanced or if the 35 is going, but since it only seems to vibrate above 50-55 mph, I'm starting with tire balance. Now for the big one... I've got frame stiffeners from T&M Fab on the way, from the cab to midway back on the bed frame, to use as a back bone of sorts, to repair where the frame is rotting just in front of the front leaf spring bracket is, just under where the cab and bed meet.
Really happy I have my plasma cutter now, going to make this a lot easier!
