What steering are you running? I think I remember you talking about 1 ton OTK, right? I'm planning to go this route when I swap in the HP30 I'm building, but not if it's going to give me issues constantly. What TB mounts are you running?
1-ton OTK steering w/ JCR poly bushings, self-rebuilt Durango box, WJ pump, TNT OTK trackbar (hard mounts at either end) with a home made over-the-axle, axle end bracket
Idk what my issues are... there may be no issues with the 1-ton steering at all. Don't let my bitching about my problems stop you from doing a 1-ton upgrade. I swapped on my airsoft BB balanced 35" tires at the same time I did ALL of the steering upgrades so it could be any number of things.
Previously I got some wobble at specific speeds. around 30, 40 and again at 50 mph. It only turned into death wobble after driving at VERY specific speeds, aka after prolonged driving at about 30mph... but that might be caused entirely by my shitty caster and (maybe?) insufficiently balanced tires.
I'm still debugging but I'm blaming myself on this one, not the steering parts
First of all my caster sucks; I need to build my 3-link. Two, maybe there aren't enough BBs in the tires to sufficiently balance them. Three, after rebuilding my steering box I clearly didn't adjust it perfectly... my adjustments today made it A LOT better but I think it's still a bit loose and I'll fix that later this week. Four, maybe I XXXXed up reaming my knuckles since I did it by hand rather than with a drill press... then again they might be fine but it's still a possibility.
Long story short I changed so many different parts of my steering at the same time I can't tell what's actually going wrong. Since the wobble/vibes come and go as I accelerate I'm sure the tires aren't perfectly balanced but I'd like to think that (if everything else was working properly) even slightly out-of-balance tires shouldn't cause death wobble.
