desertred
- Along the Wet Mountains, CO
88XJ, 4.0L. My blower motor stopped working after I finished installing a new stereo head unit. It does not function at any speed (not a vacuum leak causing the blower to default to high speed). The 25 amp under dash fuze is fine. I disconnected the blower motor under the hood and ran jumpered it directly to the battery and the motor fired right up. I'm assuming I may have a bad blower switch, but was wondering if anyone knows of a way to function test it to see if its good (everything appears to be in working order)?
Of course, this happens just as the cold weather moves in (9 degrees a couple mornings ago).
