rquarte
- Long Island
It appears my transfer case is stuck in 4wd. I can crawl underneath and move the lever fine through all the positions on the tcase by hand but when I go to test drive it in 2hi the jeep goes. (I'm just using the front drive shaft so I know its moving in 4wd) I can shift through all the positions fine with the in cab shifter too. 2hi,4hi,N,4Lo i can feel it shift but in 2Hi its still moving which makes no sense. I'm using a novak shift cable so its not the linkage and the case worked fine a few weeks ago. Now it seems something is internally wrong or the lever is messed up on the outside? Any ideas?
