- Cheyenne, WY
From now until December 31st get a FREE set of Chassis Stiffeners (normally $120) when purchasing a Rock-Tek Y-Link Upgrade for your XJ.
T&T Customs long arm suspensions come with our original High Clearance Radius Arms. Their original and unique design offers the following benefits:
- Clearance over obstacles
- No loss of turning radius
- Allows for deeper off-set wheels
- Driver's side lower arm provides driveshaft protection
- Fully adjustable components allow for pinion angle and wheel base
configuration
- Best Ground Clearance with integrated Transfer Case skid
Two piece belly pan is constructed of 1/4" Steel plate and offers over an inch of ground clearance gain. The belly pan is the new mounting point for the lower control arms. This unique design offers the following benefits:
- Removable transfer case protection for easier servicing
- Through frame crush sleeve mounting
- No weld install
- High mounted control arm mounts
Our Y-LinkTM Long Arm Suspension Upgrade is designed for those wanting to upgrade their existing suspension to the a high quality long arm suspension. This upgrade will provide a noticeable improvement in on road handling, returning your Jeep to better than stock. On the trail you can expect a significant improvement in the ability of your Jeep, even on the most demanding trails.
T&T Customs introduced the Chassis Stiffener nearly six years ago! :cheers:
Features & Benefits:
- 3/16" Steel Construction
- Eliminate Chassis Flex
Jeep Cherokee XJ and Grand Cherokee ZJ were originally designed to do the mall crawl in questionable weather, not to climb a 30-foot waterfall. As a result, the unibody will flex and eventually get bent out of shape causing issues with door-fitment, rear hatch misalignment, creaking and groaning while driving, cracking and many other less than pleasant issues. We've dug up an old trick and brought it to the Jeep XJ/ZJ world. Using our Unibody Stiffeners by themselves you can establish a chassis sub-frame where there never has been one.
Order yours today!
configuration
- No weld install
Order yours today!
