supsa NAXJA Forum User Location seattle Dec 18, 2007 #1 So I have a 231 J with a 21 spline count that I need to replace with my 231j with the SYE and 23 spline. So my question is how hard is it to replace the splines. I need the SYE t-case to be 21 spline and don't want to damage it by pulling it apart
S Slo-Sho NAXJA Forum User Location The 2nd most regulated state. Dec 18, 2007 #2 If you know what you are doing, it will not be damaged pulling it apart. And that's a BIG IF.
JeepinCoastie NAXJA Forum User Location jersey shore Dec 18, 2007 #3 its fairly easy .... just gotta take your time ...
supsa NAXJA Forum User Location seattle Dec 18, 2007 #4 Will the spline just come out after unbolting it or is there a trick
JeepinCoastie NAXJA Forum User Location jersey shore Dec 18, 2007 #5 u have release the whole planitary gear set up and then a lock ring holds the input shaft to the planitary gears
S Slo-Sho NAXJA Forum User Location The 2nd most regulated state. Dec 18, 2007 #7 Get yourself some good snap ring pliers, if not you're going to be in for a real treat.
JeepinCoastie NAXJA Forum User Location jersey shore Dec 18, 2007 #8 Slo-Sho said: Get yourself some good snap ring pliers, if not you're going to be in for a real treat. Click to expand... HES NOT KIDDING! i had a crap pair and all i did was :banghead:
R RCP Phx NAXJA Forum User Location Phoenix,Az Dec 18, 2007 #9 It would be alot less work to just swap out the SYE!
Yucca-Man NAXJA Member # 683 Location Castle Rock, CO Dec 18, 2007 #10 Umm...are you aware what a 'spline' entails? Splines cannot be removed or changed out...etc, etc Jim
JeepinCoastie NAXJA Forum User Location jersey shore Dec 18, 2007 #11 yea u can u swap the input shaft .. i just did it
