I was wondering if anyone had any advice on how to change my rear CV joint. Because they seem to be connected in the middle and i don't know if you can take one out at a time.
granted his is done on the front d/s but it's the same as a rear cv d/s.
i've rebuilt both of mine (front/rear) they were the same essentially. fyi my front d/s had 115k on it when i rebuilt it and the centering kit was fine... so since they are kinda spendy u may want to check yours out before u spend the cash. u may also want to have a needle fitting for your grease gun since u need that to grease the cv applications (they don't use standard zerk fittings) otherwise it's straight forward.
