Sway Bar torque specs
t-cell
Yucaipa, Ca
Hi, can anybody provide me with the torque spec's for the bolts, on the front sway bar, and sway bar links. I am replacing all the rubber bushings on the sway bar, and rubber grommets on the sway bar links.
Thanks!
Theres nothing critical here, I locktite (medium), and tighten hand tight. Never had one come loose in 6 years of abuse.
I'll load up all data in a minute and see if it lists one...
Stabilizer Bar
Clamp Bolt . . . . . . . . . . . . . . . 54 N·m (40 ft. lbs.)
Link Upper Nut . . . . . . . . . . . 36 N·m (27 ft. lbs.)
Link Lower Nut . . . . . . . . . . . 95 N·m (70 ft. lbs.)
