Yes it is possable but it depends on your setup. I did a full 3in BDS with 1.5in pucks and shackle for a total of 4in lift and i dont have any problems with it and i still have the short arms. I do recommend using longer shackles to help the rear end flex, it helped me.
You can add coil spring spacers to any level of lift coils on your Jeep I believe, I had a 1.75" coil spacer in the front of my Jeep with 3.5" RE coils. Pros would be that it is cheap, cons could possibly be that longer coils would probably flex and ride better than a shorter coil + spacer.
