Muddy98
- Medford, OR
so i installed an aftermarket header and now my driveline is hitting the exhaust, the headers slightly touching the oil pan and its driving me nuts.
on almost any acceleration i get the clunk and a nice exhuast tick
when i bought my jeep it was doing the same thing then i straightpiped it and it went away, before taking iv taken off and retightened the flange about 10 times with the whole exhaust disconnected and connected iv bent what will bend with a jack and a pry bar sometimes it gets a little better sometimes worse..
this is a picture from another post with a bumpstop problem that was resolved, but is the same thing happening to mine but mine is up higher a couple inches.
98 xj, no lift or suspension upgrades yet
cold air intake
header
straight pipe cat delete
703 injectors
iv checked my motor mounts and theyre good, tranny mount gives a tiny amount of play so i doubt its that..
the y pipe is stock so i dont get it. it looks as if i need a lift kit or the motor just needs to be raised an inch or two but the mounts are good so what gives?
before i put this header on there was no tick and no clunk. what i also dont get is when i feel around for a tick near the flange there is none, it almost sounds like just lifters but my lifters never made noise before the header.
my jeeps been takin care of very well, its not beat up at all not one dent. you can tell when a jeep has never been offroaded and this one hadnt. iv only takin it out a handful of times but even on hillclimbs and full throttle it never clunked.
any input would be much appreciated i dont have anything to do today but work on the jeep so ill be either on here or doing that :wow::doh:
cold air intake
header
703 injectors
