97xjcrawler
- Baldwin, KS
Went to regap all my spark plugs to hopefully help the starting issue I have been having(Post Title "Starting Issue"). All the plugs were just a little off nothing major.
The problem I am having though is the third plug from the front will loosen a little when I try to remove it, then it just tightens up after that...and yes I know righty-tighty lefty-loosy. As of right now I have it backed out the little it will move and sprayed WD-40 on the base to hopefully seep into the threads.
I am pretty sure that the threads got cross-threaded when I replaced the plugs last...not sure though but that's probably why its not coming out.
ANY ideas on how to get that thing out without having to pull the head?
